Hikvision 7608NI-SE2/8P - Problem Displaying All 4 Cameras in 2*2 Multiscreen
I'm new to NVRs, IP Cameras, and this forum... so I would appreciate any help!
I just installed 4 brand new Hikvision cameras and a new Hikvision 7608NI-SE2/8P. I bought it from Nelly's and used their free pre-configurations services, so all I had to do was hang the cameras and plug everything in. Everything works perfectly, except...
On 2*2 Multiscreen mode it only displays 3 of the 4 cameras. On the fourth quadrant is shows "No Resource". And it is not the same camera that drops out when I switch to another view and then back to 2*2 mode. It can be any of the four quadrants that displays "No Resource" when I switch to the 2*2 mode.
And in all other modes (1+5, 1=7, etc.) all four cameras appear.
The cameras are: 1 2CD2632F-I, and 3 2CD2032's.
From my internet research, I believe the multi-screen views are driven by the Substream configuration. The Substream configurations are all exactly the same for all four cameras with one small difference:
Stream Type: Video
Resolution: 352*240 (CIF)
Bitrate Type: Variable (here the 2632 has "Constant")
Video Quality: 4 out of 5 green bars
Frame Rate: Full Frame
Max Bitrate Mode: General
Max Bitrate (Kbps): 512
Max Bitrate Recommended: 768 (Kbps)
My Video Output Interface is set to VGA/HDMI and I'm connected via HDMI to a 1080P 27" television.
I doubt this is related, but I CAN see all 4 cameras at once in 2*2 mode when viewing through iVMS-4200 on my Mac.
I appreciate any help or ideas you could offer. I've googled and searched on this forum, but could not find a similar problem.
TwistyRoads
Stream Type: Video
TwistyRoads
