Hi All,
Just about to pull the trigger on a NVR and cannot work out what the difference between the two are
DS-7616NI-E2/16P - Embedded plug and play NVR
DS-7616NI-E2 - Embedded NVR
What does the plug and play version do, or do I need it?
I believe the 8P or 16P is the number of PoE ports on each PVR, with various configurations available
Is it worth buying the UK/Aus version rather than Chinese one? Only limit seems to be not being able to update firmware
This will be for a home system.
Currently thinking about using one of the following cameras
DS-2CD2132F-IS (3MP dome)
DS-2CD2332/2335 (3MP EXIR)
Also looking at purchasing from either
- Aliexpress $315USD Inc Shipping - 8P
Ebay $320 USD inc Shipping - 8P
16P models are more expensive
I'm in Australia if that makes any difference
Thanks in advance
John
Thanks in advance
John
