- May 14, 2014
- 4
- 0
Hi, I was wondering if anyone had experience with any of the 4 series hikvision cameras, specifically those with heated sensors for cold climates?
You see, I live in Wisconsin and the temps hit -20F here at least a couple days in the winter, not to mention the windchill has been down to -40F for short periods. As I don't want to damage the cameras or have any downtime, I believe I should go with the heated versions which appears to only be available in the 4 series.
http://overseas.hikvision.com/en/products_164.html
Anyone have experience with these cameras? If not, have you experienced any issues with your outdoor cams in really cold temps?
Having them heated allows the temps to drop to -40F from the standard -22F according to the spec sheets.
Thanks for any insights. Also if you have a cheap place where I can source the 4 series, that would be great to know as well.
