- Aug 26, 2014
- 15
- 0
Hi guys, I recently purchased two Hikvsion 2T42WD-I5 4MP EXIR IP cameras for my NVR - which is the Hikvision ds-7608ni-e2/8p firmware version 3.3.6 build 151229. Because the NVR is running on a property overseas I tested the cameras here in the States using Blue Iris prior to sending them to Europe. They worked fine, but I made a mistake by not resetting them to factory default settings prior to sending them. When a relative of mine (located in Europe) tried connecting them to the NVR, they were not detected. The IR light would show that they have power via the POE port on the NVR, but when the person connecting them checked the NVR display and I checked it remotely - they just wouldn't show up.
My question is what are my options now?
I'm not really familiar with these particular cameras and can't find a manual for them online that would show the location of the reset button. I assume that it's somewhere in the front under what covers the lens and the IR lights. If anyone is familiar with these particular cameras, please let me know.
My second option is asking my relative to connect them to a router (they would have to buy a POE injector first) and from there I would locate the cameras using Team Viewer and reset them to factory settings. I know how to change the IP on the router using the necessary Hikvision tools, so that part is not a problem.
My NVR is currently running a Plug & Play configuration.
