Hikvision 2CD-2132 USA version and I can't get it to power up inside LED isn't illuminated.
I have a Hikvision 7616 16p POE and it was set to Auto on the POE but changed it to POE-af I think it is.. and the other 4 2cd-2132's work perfectly.. just not this one.
I also tried plugging directly into a separate POE switch and don't get a light or IR that way either.
I've also tried holding the reset down and then powering up but that fails to get any results.
Let me know if you've seen this before or have any suggestions.
Thanks
Jody
Thanks
Jody
