Hi to all,
I have about two dozen Hikvision cameras in various locations all installed by me for personal use: 2142, 2542, and 2642.
Half of them, about a dozen, are mini-dome 2542. Of these and only these, two have their IR-cut filter fail after less than one year: the filters would remain parked in the night mode or day mode.
The cameras are all installed indoor on a vertical wall and powered by PoE via various Zyxel GS1900-8HP. I rule out power issues as the same cameras worked well for months, and other cameras (2142, 2642) still work attached to the same switches.
I opened the lens balls, shaked them, cycled the cameras between day and night, rebooted several times, but none of these actions fixed the IR-cut filters that seem to behave as they are unpowered: the filters move by hand (not stuck) but cameras cannot move them and I don't here the "click" sound at power up.
No firmware updates occurred before the filters stopped to work and all cameras, working and not working, have the latest firmware.
I am attaching a picture of the filter in question, that is screwed to the electronic base and glued to the lens, so it as the 12mm thread. It is marked as Hikvision.
Anybody knows where I can buy them? Any Google or AliExpress search I did, did not return the correct part. Hikvision USA is of no help as I bought the cameras on AliExpress. I would hate to have to rebuy $100+ cameras instead of a couple dollars part.
