klasipca
Banned
- Mar 27, 2014
- 3,137
- 750
You can try reducing bitrate, resolution, fps, also not every router is equal and environment varies, so you may need a repeater or a powerline adapter. I am running three 2432 cams as baby cams at different locations in the home. All of them use wifi, @ resolution, 10 fps and 3000 bitrate.
As far as power plug if you are ok with the limited length then it's fine, but if you want flexible cable placement it's best to use POE plug where you can have any length for your power cable.
http://www.ebay.com/itm/Best-Univer...-Camera-NEW-/311414046579?hash=item4881b93f73
