- Feb 14, 2015
- 14
- 0
I have the 2132 cameras with the reset button and the stated nvr with poe. Everything initially set up perfect and all the cams got recognized and successfully generated feed online and local. Problems start with any brownouts or power shut offs. All the cams come back as offline and no matter what I do, short of resetting every last one of them, leads to nothing. I have to physically reset the camera to bring it back online. Needless to say.....pita. Resetting or restoring the cam in the cam menu or the nvr menu accomplishes nothing. The nvr has a sub nic of 192.168.254.xxx which auto assigns ips to the camera in that domain. I have no ports forwarded for the cams. I have all the ports forwarded in my router and canyouseeme hits them all successfully. The cams originally had the factory default ip of 192.168.0.xxx (or something like that) which I changed to 192.168.1.xxx. Like I said, after it was all fired up the cams were given 192.168.254.xxx ips by the nvr. I have a DSL connection set for bridged ethernet to the router (PPPOE). I am not using pppoe in the nvr setup. I am using tcip settings. I am at a complete loss. Also, when I tried to set up the hik-online ddns server it stated that the nvr device was offline. I was able to access it the first time but now I can't. I can access all cameras via laptop plugged into nvr. Any help would be greatly appreciated. I am very time constrained on this. Thanks!!!
