P peesen n3wb Apr 25, 2025 1 0 Aarhus Apr 26, 2025 #1 Hi guys i'm starting my old Hik vision NVR DS-7604N1-E1/4p/A up again and forgot password. how do i reset without no reset button og jumper.
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 21,573 51,218 Alabama Apr 26, 2025 #2 Try IPCT's tool here => Hikvision Password Reset Tool It's to be used in conjunction with Hikvision's SADP Tool here => SADP Tool
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 21,573 51,218 Alabama Apr 26, 2025 #3 @alastairstevenson , do you know if this method ^^ will work?
alastairstevenson Staff member Oct 28, 2014 16,409 7,175 Scotland Apr 26, 2025 #4 TonyR said: @alastairstevenson , do you know if this method ^^ will work? Click to expand... There is a fair chance it will work OK. I'm hesitant to suggest using the Hikvision tftp updater, which on those old NVRs would likely reset to defaults, as the NVR is a Chinese model and the acceptable firmware would be hard to find. Reactions: TonyR
