Hi Guys.
We recently purchased a house that came with a hik vision set up (nvr and 6 cameras)
when the owners left they reset and disconnected the cables from the system and didnt supply us with any of the details.
When trying to reset the login details I am met with needing a security code, if I were to get past that I would then need to send them a xml file.
unfortunately it would appear that they purchased the system away from normal authorised channels (Ebay or amazon we dont know). and have told me that they will not assist.
Is there anything that I can do?
If not thanks for your time anyway.
Cheers.
Cheers.
