Hik POE, IP address troubles HELP!?!
JohnDear
Oct 12, 2025
1
ireland
So to keep it short, i bought 2 Hilook POE cams afew months ago, set them up no problem. Then a while ago bought an extra 2 of the exact same cams so i could have 4.
there all connectd to the NVR, But the 2 newest arent posting on screen. iv tried to fix it by reseting the camera with the reset button on the camera.
I went into the NVR settings and changed the IP there to a similar one as the ones working and nothing still.
They do all work, because when i reset the cams the nightvision light flashes on and back off. And the NVR reckonizes their there but cant post on screen.
Im aware of SADP tool aswell, iv no access to a laptop with a ethernet port right now. i just have a PC with 1 port and if i use that the PC wont have internet (not sure if that matters)
I kinda know what im doing but i dont know Exactly how to, so a dummys guide would be great if possible lol
Cheers
Can post some pic that might be more explanitory
Dear John,
What is the NVR model number and firmware version?
Do you have a monitor and mouse connected to the NVR or are you using the NVR web GUI?
If you can, post a picture/screenshot of your devices page:
