I have a hikvision NVR (purchased from LTS, model: LTN8704-P4). Everything has been working great up until a week ago - nothing has changed as far as the network or NVR. I can log onto the config remotely, but remote streaming won't work on the web, client software, or mobile app. I see this error code in the NVMS7000 client software while trying to view camera stream remotely:
Reconnecting.Error Code HCNetSDK.dll[7].(Connecting to device failed. The device is offline or the network timed out.)
I made sure NVR, client software, and app are updated. DDNS is working fine.
Followed troubleshooting steps in manual for client software:
Anyone recently have any of these issues? I googled the error code and found a guy that said his ISP had blocked some of the traffic from the gateway. Ugh. I hope I don't have to deal with my ISP on this - I can see it taking 3 hrs.
Edit: Called ISP to make sure there was no chance of the modem blocking anything. The confirmed it can't and doesn't. Back to square one.
- Check network status and disable other not in use process on your PC.
- Check the device network status.
- Restart the device or disable other remote access to the device.
- Log in with the admin user and try again.
- Download the client software of the latest version.
