I've been digging into the email problem for sometime now. I originally thought it was Gmail related but I've just discovered & tested an odd success. When NVMS7000 (LTS version of remote client) or iVMS4200 is open & running on my desktop they will send email alerts (for line crossing & motion detection, but without image attachment). However if you "Test" email in either of these programs you will get a FAILURE from one menu and a SUCCESS from another menu. Now, if I go to web portal - which is what I'd been using for the last 5 months - emails fail all over the place regardless of how they are tested.
Also of note - I have to setup the line crossing in web portal for it to work. I cannot set it up in VMS. I CAN setup motion detection, but it doesn't save.
I ran a few tests on this theory and sure enough, I got a ton of emails while either program was up. I've just run a final test where neither VMS was running on the desktop at all, and the web portal was closed & I broke the line on 2 different cameras. I had my phone on me and didn't receive any notification. By the time I got back to the computer and logged back in it was roughly 5 minutes later and still no emails. However once I logged into NVMS7000 I got a series of 4 emails stating line break. The emails were time stamped for 1:11 & 1:12 AM CST, and the text of the alert in the emails said the same but that was the time that I sat down and logged in. I looked at the footage - I was out there @ 1:06 & the system time is in sync with the desktop as well as the Gmail time.
Now - I'm still unable to get email to work with Gmail (my main account nor a new NVR specific account with all the bandaids), nor Outlook. Initially I couldn't get it to work through SendGrid either (using WebPortal), but SendGrid non secure is where we are at now (STILL not working through web portal).
Also - I'm still unsure as to why but the emails are showing up dated 13 hours behind the system time in Gmail. This may be a function of SendGrid or Gmail or the local programs. Low on the priority list at the moment.
Now - I went out and broke the back line again, with the programs all closed. No emails or notifications. After I post this I'll login into VMS and see what happens.
Please tell me someone has some constructive thoughts on this... the system has been absolutely great otherwise.
LTN8708-P8 firmware V3.3.2 build 151208 web version V4.0.51 build 151208
Camera shwon is a Hikvision DS-2CD2342WD-I firmware V5.3.8 build 151224 web version V4.0.1 build 150915, but I also tested on a LTS branded dome at the same time.
I promise that I triple (and then-some) checked all the network information across interfaces.
