Hik DS-7608NI-E2 set up
lovedgor
Feb 7, 2016
54
25
I have this NVR up and running with one Hik DS-2CD2042WD-I and can access the NVR from IE and configure. I enabled virtual host and I can adjust the image directly from the NVR, but I do not have an image on the live view tab. Any ideas?? I've tried different RTSP ports, as the manual gave suggestion for verizon, but that didn't work either.
Did you install webcomponents from the camera or from the NVR?
It's likely that from the camera is more up to date.
Maybe a de-install / re-install as an experiment?
Reactions: lovedgor
What settings do you have in Live View under Local Configuration?
These are the default enables:
TCP, Main Stream, Auto, Disable, Auto fill
Protocol TCP UDP MULTICAST HTTP Stream Type Main Stream Sub Stream
Play Performance Shortest Delay Auto
Rules Enable Disable
Image Size Auto-fill 4:3
Reactions: lovedgor
My settings are: TCP, Main Stream, Auto, Disable, Auto Fill, BINGO Thanks for the suggestion. Auto Start did the trick.
