Hey all,
Newbie to hikvision gear so please be gentle haha.
Did a lot of reading regarding sensor sizes and what not and am happy with the results out of the box so far (just need to research into dialling in the settings and then using said settings for day/night modes).
So I have a HIK-2CD2386G2-IU accusense out the back and a HIK-2CD2367G2H-LISU/SL colorvu hybrid out the front (still need to install the second one).
I have disabled the motion detection under normal events in both NVR and through the IP cam connections. I am using the exact same settings for both cameras in the intrusion detection options (setup via IP cam login) however my phone will only get notifications for the colorvu cam. The accusense cam notifications for a triggered event do however show up on the DVR when accessing it via tv/HDMI.
I have reset the settings and played around yet can't find why one is working and not the other.
My other issue with the same accusense cam is that when it starts to darken off a bit the shutter sometimes shuts and sets off the video tampering alarm (I just need to adjust the sensitivity of this hopefully) yet the day night switch is not on auto but a schedule. Not sure if it actuating the shutter for a friend second or so is normal or not.
Look forward to you bunch sharing some knowledge to help sort my issue!
Cheers,
George
Cheers,
George
