Hi all, perfect time to spend the next few days installing cameras
I have an existing in-wall network cabinet where I will run all my shielded network cables down into from the attic. In that same bay is a power line from the attic going to the outlets on the bottom of the cabinet.
I plan on moving the power line to the next bay before joining it back to that bottom outlet. Now I can keep everything above the cabinet clean and clear for only network cables.
So at worst, I should still satisfy the NEC standards for unshielded of 8" proximity? Since I am using shielded network cables, I should be fine right? No cable runs should be longer than 75ft.
Would it help any to put that power line (already in the next bay) in a grounded metal conduit?
My second scenario is my detached garage. I would love to put an in-wall cabinet in the next bay right next to the breaker panel. I know I should give myself more room say skip one bay? Will putting it in the adjacent bay be a terrible idea?
Thanks and Happy Thanksgiving!
