Simply reverse the procedure.page 391 has some trip wire setup info, but seems to talk about enabling it. not much there in terms of hiding blue lines.
settings in where? can't find in smart pss or nvrDid you go to "display" under "settings" and then turn off "AI Rule?"
On your Dahua NVR, go to the main menu and login. You will then click on "settings." You get there by clicking on the right arrow at the bottom of the screen (just under "maintain"). After clicking the right arrow you will see "display." Click on that and slide the slider to the left that says "AI Rule."settings in where? can't find in smart pss or nvr
It should look like this.settings in where? can't find in smart pss or nvr
Wow-Thanks that sorted it, much appreciated.On your Dahua NVR, go to the main menu and login. You will then click on "settings." You get there by clicking on the right arrow at the bottom of the screen (just under "maintain"). After clicking the right arrow you will see "display." Click on that and slide the slider to the left that says "AI Rule."
It hides it from showing on the monitor.So does this turn IVS off altogether or does it just hide the lines from the picture on the NVR monitor?
