HI3520 DEBUG BOARD VIA UART
cdxxxcarvn
Sep 28, 2021
4
Vietnam
Hi everybody. I'm using board HI3520 from silicon company. when i was trying to connect with board via UART DEBUG, It's seem finished. But, console in Desktop ( Desktop connected board via HDMI) not appear. therefore, What is the problem that I am facing? thanks everyone !!!!
Make real photo from your board with uart connection.
What's the problem?
No log after starting kernel?
  • Love
Reactions: cdxxxcarvn
Interrupt the bootloader and use 'printenv' to show the environment variables.
Sometimes these control the level of detail passed to the serial console from the Linux kernel.
It might be interesting if there is one called 'dh_keyboard'.
  • Love
thank you. let me try it. i will respond soon to you. Have you done it on this board and had the same problem?
would you Speak clearly? Sorry, i'm just beginner!
In the old days, the Linux console device was always assigned to /dev/ttyS0 (that's 'tty' for teletype, an ancient thing I used way back in the late 1970s) The S is for 'serial', describing the port protocol, and the last character is a zero, meaning the first tty/serial device on the system.
Later changes to the Linux kernel specifically for the HiSilicon chips considered the internal nature of the console/serial ports, and described them as AMA devices instead of 'S'erial. The last character is still a zero, meaning the first AMA port.
Now, that's all for the history lesson. :D What hardware / firmware people have done in the last couple of years is attempt to obscure or hide the console serial port, by moving it away from device zero and over to device one or device two. In this way, it does not display the boot log or console i/o on the previously default /dev/ttyS0 or /dev/ttyAMA0 devices.
The way to defeat this is to (somehow) interrupt the U-Boot boot sequence, and override the kernel/console startup commands. Specifically, you'd forcibly re-direct the console output to /dev/ttyS0 or if that does not work, then /dev/ttyAMA0.
Reactions: alastairstevenson
