Hi all
my plan is to put up 4 outdoor cameras and 2 indoor, I got 4 4k Amcrest and 2 5mp Amcrest cameras, I bought by Amcrest because I didn't want to buy Chinese cameras that talk back to china, I only learned after the fact that most if not all cameras come from china with different branding.
I still need to buy a PC for blue Iris, I read that you can get a cheap used PC for ~200 that would work great with BI, I'm confused which PC to buy, is there a reason to keep away from SFF or micro towers? does it need to be a dedicated PC or it can be a general use PC that also has BI on it?
in the picture below you can see the lights have a terrible reflection, what setting would make it look better
I read that the lower MP is better for night vision, does that refer to the camera specs or recording settings, which means if you set a 4k camera to record on a lower res would you get the same result as a 4mp camera?
another reason i went to amcrest is i read that dahua cameras is very expensive when bought directly or very cheap when bought on aliexpress bought those cheap ones don't have a warranty and they cant be upgraded and they don't work with north American variant, after reading up over here there seams to be someone Andy that sells cameras from dahua reasonably priced,
question is how does andy's cameras compare with the rest of the sellers on ali or amcrest, is he a reputable seller that backs his products and is it upgradable with North American Variant and what about a warranty?
thank you all for your time.
