- Sep 22, 2015
- 16
- 0
I thought I counted 6 wires from the picture. Sorry, I really don't know what type of connection it requires then. Good luck.
ok, I see there is an ethernet port on the camera...so it is an ip camera, i guess you are trying to use it with the analog output to a standard DVR...so the seven wires are for some sort of interface like RS-485 RS-232C, RS-422. I have no idea how they need to be wired..You might simply consider hooking it up to your network and controlling it with a mobile app or pc...Thanks @fenderman But this camera has me stumped !! I'm lost.
yes, you are correct. I noticed it a few minuets before your post when i looked at the photos again.@fenderman I might be wrong, but isn't there an ethernet port staring us in the face on one of the pictures? You can see the copper pins going in the rj-45 shaped hole.
you could...you need to figure out the 7 pin wires....the point is this is actually a network camera and you can view the camera using a mobile app or pc AND also connect it to your dvr...using the mobile app you can easily move the camera.Ok guys. Now I'm Officialy lost.
Basicly I can't hook this up to my dvr? Even though I'm getting picture and power. No way to control the ptz!
