Hi I have a NR32P8-8, Not sure the Brand but I think it runs Hikvision software ( Not sure though ) . The NVR stopped recording and the HD said Abnormal, I initialized it and it worked for a little bit then stopped recording again. I tried to run disc checks but stops and says to many bad sections. I am going to install a new HD this weekend, I can't find a format option but I think the HDD INITIALIZE option is the same thing?
I should not loose my network settings when changing HD?
Is there a way I can back up my settings just in case I have an issue in the future?
Should I update Firmware and if so how?
Thank you, I am not knowledgeable in this area and I appreciate the help.
Firmware version V4.21.005 build 191218
Encoding version V5.0 build 190701
Web Version V4.0.51 build 190529
Plug in Version V3.0.7.10
