Hi from Croatia
zoky
Jan 26, 2020
3
4
Croatia
My name is Zoran, just checking in to say hello.
I'm quite new in Blue Iris and home surveillance but I'm happy to learn.
So as every newb I figured to hit the ground running and bought my self some cameras.
Among which, one Imou Cue 1080p... and of course, it was impossible to get a live stream out side of dedicated Imou app.
Long story short, I found a way!
To tap in to it's rtsp stream type in this:
you just have to set the password first in the app and then use it here
Since this is quite handy little cam for indoors and there's no such info on whole internet, i thought I'd share it here.
Hope it will be helpful to somebody.
Looking forward to digging in to here!
Sorry for possible bad English.
Cheers
zoky
:welcome:
Welcome to the world of video surveillance lunatics. Be sure to look at the WiKi, in the blue bar at the top of the page, and study, carefully, the Cliff Notes that are in there. It'll save you lots of time, money and frustration.
Reactions: zoky and mat200
:welcome:
My standard welcome to the forum message.
Please read the IP Cam Talk Cliff Notes and other items in the IP Cam Talk Wiki. (read on a real computer, not a phone). The wiki is in the blue bar at the top of the page.
Read How to Secure Your Network (Don't Get Hacked!) in the wiki also.
Quick start
1) If you do not have a wired monitored alarm system, get that first
2) Use Dahua starlight cameras or Hikvision darkfighter cameras if you need good low light cameras.
3) use a VPN to access home network (openVPN)
4) Do not use wifi cameras.
5) Do not use cloud storage
6) Do Not use uPNP, P2P, QR, do not open ports,
7) More megapixel is not necessarily better.
8) Avoid chinese hacked cameras (most ebay, amazon, aliexpress cameras(not all, but most))
9) Do not use reolink, ring, nest, Arlo cameras (they are junk), no cloud cameras
10) If possible use a turret camera , bullet collect spiders, dome collect dirt and reflect light (IR)
11) Use only solid copper, AWG 23 or 24 ethernet wire. , no CCA (Copper Clad Aluminum)
12) use a test mount to verify the camera mount location. My test rig: rev.2
13) (Looney2ns)If you want to be able to ID faces, don't mount cams higher than 8ft. You want to know who did it, not just what happened.
14) Use a router that has openVPN built in (Most ASUS, Some NetGear....)
15) camera placement use the calculator... IPVM Camera Calculator V3
16) POE list PoE Switch Suggestion List
Cameras to look at
IPC-T5442TM-AS-LED Review IPC-T5442TM-AS-LED (Full Color, Starlight+) - 4MP starlight
IPC-T5442TM-AS Review-OEM 4mp AI Cam IPC-T5442TM-AS Starlight+ - 4MP starlight+
IPC-B5442E-ZE Review - OEM IPC-B5442E-ZE 4MP AI Varifocal Bullet Camera With Starlight+
IPC-T2347G-LU Review of the Hikvision OEM model IPC-T2347G-LU 'ColorVu' IP CCTV camera. (DS-2CD2347G1-LU)
IPC-HDW2231R-ZS Review-Dahua IPC-HDW2231RP-ZS Starlight Camera-Varifocal
IPC-HDW2231T-ZS-S2 Review-OEM IPC-T2231T-ZS 2mp Varifocal Starlight Camera
IPC-HDW5231R-ZE Review-Dahua Starlight IPC-HDW5231R-ZE 800 meter capable ePOE
IPC-HFW4239T-ASE IPC-HFW4239T-ASE
IPCT-HDW5431RE-I Review - IP Cam Talk 4 MP IR Fixed Turret Network Camera
DS-2CD2325FWD-I
N22AL12 New Dahua N22AL12 Budget Cam w/Starlight -- low cost entry
Other dahua 4MP starlight Dahua 4MP Starlight Lineup
My preferred indoor cameras
DS-2CD2442FWD-IW
IPC-K35A Review-Dahua IPC-K35A 3mp Cube Camera
If interested in Blue Iris and other setup items see the following post
Camera Sensor size info Sensor Size Chart Generally bigger is better
Before asking a question search the forum first...
The best way to search the forum is to use Google Advance search
set site or domain to ipcamtalk.com
OR
in the google search window enter.. site:ipcamtalk.com ?????? ..where ?????? is the items/terms you are interested in.
Example site:ipcamtalk.com PALE MOON BROWSER
Read,study,plan before spending money ..... plan plan plan
Test do not guess
Hello zoky, welcome to the forum
FYI - adding the following to make it easier to search
imou Cue 1080P ip camera
rtsp stream ( see post #1, thanks @zoky )
rtsp:/admin"[email protected]:554/cam/realmonitor@channel=1@subtype=1
( remember to use the IP address that the Cue camera get's from the DHCP server, or the one you assign )
