First of all my apologies for all the newbie questions and confusions.
We have an existing camera system with dahua IP eyeball cameras NT-HDW4421EP-0360B and dahua WiFi cameras: DH-IPC-HFW1320S-W with existing dahua NVR NT-N4104-P all working great for a few years now. We are not using the built-in POE on the NVR but an external POE switch. The camera system is working on 192.168.20.x range.
Recently, we bought more cameras, DH-IPC-HDW4631EMP-0280B 6MP Eyeball and DH-IPC-HFW2831SP-S-0280B-S2 8MP WDR IR and a new NVR DHI-NVR4216-16P-4KS2 16 Channel 1U 16PoE.
The new cameras work well with the new NVR including the already existing wifi cameras but I could not get the existing IP eyeball cameras NT-HDW4421EP-0360B to work with the new NVR.
I have reset the new NVR several times and reset the existing eyeball camera.
I have reboot the NVR and cameras several times as well.
I have re-terminate cables. I have changed IP address on the eyeball camera. Tried DHCP or static.
I have tried connecting directly to built-in POE bypassing external poe switch (10.1.1.x range).
Disabled UPnP and P2P. Reset the passwords on NVR and camera.
Unchecked the ARP/Ping option.
But the result is still the same.
The issue is either “Offline” or “Can not find the network host". Logs also show the same error.
Randomly for a brief second, you could see the video working but will then switch back to a blank screen with the errors mentioned.
If I reconnect them back to the old nvr it will work straight away.
Looking to upgrade the firmware but could not find any for the eyeball camera NT-HDW4421EP-0360B.
Is there something I have missed or have to do with integrating the old cameras with the new NVR?
Appreciate anyone's help and guidance. Thanks.
