HFW2431s-sp-s2 , recommended?
Jomsha
Oct 26, 2019
99
18
N/A
Hi,
Its 1/3" sensor. But I think its the new generation.
Min.Illumination 0.008 Lux @F1.6
What you guys thinking ?
If you need night vision go with a 5442 camera that has a 1/1.8 sensor.
IPC-T5442TM-AS-LED . Review IPC-T5442TM-AS-LED (Full Color, Starlight+) - 4MP starlight
.................... Dahua IPC-T5442TM-AS-LED review
IPC-T5442TM-AS ..... Review-OEM 4mp AI Cam IPC-T5442TM-AS Starlight+ - 4MP starlight+
IPC-HDW5442t-ZE .... Dahua IPC-HDW5442T-ZE 4MP Varifocal Turret - Night Perfomance testing -- variable focus 2.7 mm-12mm 4 MP Starlight
IPC-B5442E-ZE ...... Review - OEM IPC-B5442E-ZE 4MP AI Varifocal Bullet Camera With Starlight+ -- variable 2.7mm-12mm bullet
IPC-B5442E-Z4E .... bullet 8mm-32mm variable focus zoom 4MP
IPC-HFW7442H-Z ..... Review - Dahua IPC-HFW7442H-Z 4MP Ultra AI Varifocal Bullet Camera -- 4 MP variable focus AI
if you are interested in International Dahua cameras, a forum member sells dahua (and some Hikvision) and ships world wide. You can read some of the members recommendations on his service. He also provides cameras to other forum member for evaluation and reviews.
You can email him for a quote, or purchase from his Aliexpress store or his Amazon store. The cameras are fully upgradable, he posts upgrade software when available.
I recommend email andy
Andy
@EMPIRETECANDY
[email protected]
Andy's ipcamtalk vendor forum: EmpireTech Andy
Andy's AliExpress store: Empire Technology Co., Ltd - Amazing prodcuts with exclusive discounts on AliExpress
Andy's Amazon store: Amazon.com
I have the turret version of this cam T2431T-AS-S2. It is fine with plenty of light or on IR. But if you want color at night you better have a lot of light. Also, the version (bullet) that you are asking about does not have onboard audio.
The cam that @SouthernYankee recommended above is tops right now for low light color performance.
Reactions: EMPIRETECANDY
If want the sharpest version just use the IPC-T5442TM-AS or IPC-T5442T-ZE
based on your budget, if have plenty of light in the night, the T2431T-AS is the best to go!
