As you can see below, my front door/entrance is atypical of a lot of homes. Most homes are built with the doorbell next to the door facing the walkway. The way my house is designed there isn't sufficient room for a doorbell and therefore it's on the right side. One would assume a security camera next to or above the door would provide the best view of incoming visitors.
Wondering if any of you have a similar situation and wanted to see what you did or perhaps you have some suggestions for a typical style of camera. Seems like most of the doorbell cameras would not be a good fit for my house. I also have the desire to see packages at the door and perhaps literature left on or below the door. I was thinking about maybe a dual camera setup like Dahau IPC-HDBW4231F-E2-M. Not thrilled about domes because of possible nighttime glare but that's a tradeoff and I have turret cams around other places in front of the house.
You can see I have an old Nutone intercom doorbell which isn't worth a chit...doorbell works great but intercom sux. It's run off of standard doorbell type wiring and is powered by a typical doorbell transformer. Replacing it with an IP cam doorbell would have the camera pointing the wrong way.
The walls on this house are standard Florida CMU concrete block so it's no picnic running wire to the middle of the wall. Likely, you have to rip into the drywall on the interior side to run wire then patch it back up and paint.
So, what's a good camera and/or doorbell or other setup for this situation?
