- Oct 7, 2015
- 6
- 0
Hey everyone. I've read countless topics and watched many videos to absorb as much info as I could from the experienced experts and beginners have provided on this forum in preparations for my first install. So far the equipment plug and plays with no issue, but it's the network configuration portion that has me pounding the table. This is my first stab at getting it set up, so after a couple of days, I am still failing to get the mobile app (IVMS-4500) working, so I am now reaching out to the community for some help. So thank you in advance.
Here's the current hardware I am dealing with:
Hikvision nvr DS7608N-E2/8P firmware v3.0.10
Hikvision dome DS-2CD3132-I firmware v5.3.0
Motorola NVG589 broadband router
Here's an overview of the steps I went through setting up the network configuration. So everything seems to work fine all the way up to step 7 once I can successfully access the nvr on the hik-online.com website, I still cannot get the IVMS-4500 to list my cameras after the nvr is added? Did I miss a step?
1) Plugged in domes to poe ports, then powered on nvr and go through wizard to configure the network settings
2) NVR > Network > General, followed steps to enable the DHCP to obtain the IPv4 Address/Gateway info, inputted the DNS Server info(from broadband router's primary DNS), then disabled the DHCP
3) NVR > Network > More Settings, verified the ports Server: 8000, HTTP: 80, RTSP: 5554
4) PC > Opened a browser to access the broadband router (Motorola NVG589) ip address. Accessed the Firewall > NAT/Gaming tab to create 3 custom service(s) each with ports 80/8000/5554 assigned to the nvr ip address
5) PC > Opened a browser to access canyouseeme.org and verified each port tested a status "Success"
6) NVR > Network > Extranet Access, enabled DDNS/HiDDNS
Server Address: www.hik-online.com
Domain: <domainname>
Status: Online
7) PC > Opened a browser and went to www.hik-online.com to create a new account. Clicked on Device Management and successfully added device (nvr serial number/device domain/80)
- Clicked on Device URL Link and remoted into nvr successfully
- ISSUE found Live View only able to view one camera at a time or Fails to to connect. This is random.
- ISSUE found with Playback seems to always fail
8) iphone > Installed IVMS-4500. Added device using
Register Mode: HiDDNS
Device Domain: <domainname created from hik-online.com>
-Saves successfully, however ISSUE with camera = 0, so unable to Start Live View
Status: Online
