- May 30, 2016
- 135
- 73
I'm helping a friend install an IP camera system consisting of four outdoor cameras. The existing router is indoors, so I am going to make an interface box that will allow a cat5/6 connection to connect to the router from outside. I intended to use an 8 port POE switch for the externally mounted cameras. Here's where I could use some help by way of your experience and wisdom. Where should I mount the POE switch?
I can put it under the eaves directly above the cat5/6 junction box, or maybe to the rear of the house near the two cameras, then use a long run of cable to get to the front camera? Maybe I'm overlooking something, like another switch? What would you do?
The red triangles represent camera placement in my little sketch.
Thanks very much for any pointers.
Shawn
Shawn
