Hi guys,
Sorry if this has been done to death. I've read as many threads as I can about resetting the NVR password.
I've inherited a Hikvision system with a DS-7104NI-SN/P and three Hikvision cameras connected via Ethernet. It has never been on a network before but I've plugged it into my switch and can access the login prompt. Unfortunately nothing seems to work for the password.
I've used the SADPTool and discovered the following:
Software version: V3.0.13build 150429
DSP version: V5.0 build 150413
Using the password reset tool here: Hikvision Password Reset has not worked. Device rejected error.
Are there any other options open to me? The reseller of this device is long gone.
Thanks very much! cmdwedge
