B bergs n3wb Mar 4, 2024 8 1 USA Jan 22, 2025 #1 A year or more ago, I played with Home Assistant and MQTT. I no longer have this HA server running, but Blue Iris is getting pounded with "Connect: Failed" in the logs from object "MQTT" How can I track this down so that I can stop these errors?
J jaydeel IPCT+ Member Nov 9, 2016 1,844 1,994 SF Bay Area Jan 22, 2025 #2 Have you already tried to disable the HA MQTT server in the following settings tab? Settings > Digital IO and iOT > MQTT Configure Reactions: TonyR
B bergs n3wb Mar 4, 2024 8 1 USA Jan 22, 2025 #3 That was probably it! I disabled it. I couldn't recall where MQTT settings were. Thanks! Reactions: jaydeel
