- Mar 16, 2017
- 40
- 4
Bit of an intro first,
I installed an analogue cam system with a Dahua DVR and 4 variable lens cams over 5 years ago but the quality by todays standards is terrible so I thought its maybe time to upgrade
There only really needs to be 1 cam at my place that looks up the driveway as this is the only entry point
So I thought I'd purchase and test out a Dahua 4m HFW4431R-Z from aliexpress - (one of the main companies with lots of pos feedback)
anyway I have plugged it in to my router using a cat 5 and a 12v 1A plug pack but router and dhcp does not detect it at all?
I have tried using an older Dlink router
I have tried using another 12v plug pack and another cat 5 cable
I have plugged it into my computers Ethernet port but doesn't show it in network connections either?
the IR leds do light up on the camera when placed under desk
I have ordered a POE injector plug pack but waiting for it to arrive
I was thinking of getting a 4 channel Dahua NVR but at the mo not sure if I need 3 more cams
does the camera have to be plugged into a NVR for it to work?
I should probably add I don't currently have a viable net connection but waiting any moment for my fibre to be connected then I was going to try out some of the cloud subscriptions (in place of an NVR?)
any suggestions would be very useful
