Looking to install a camera system for the house and figured I'd build a home network while I'm at it.
I've learned so much in the last few days about IP cams but I don't know much beyond the basics of networking.
The cam system will be an NVR with 8 PoE switch that I will connect to the network via a 16 port switch.
I have my router in my office but plan to install the 16 port switch and NVR in my pantry(a/c and centrally located). My house was built with cat5 cabling from each room to a junction in the garage so I just need to do some re-routing and add lines based on camera placement.
My current setup is using 3 outputs of the router, Win10 main computer, work laptop station, linux box, and I plan on using the 4th output to go to the switch in the pantry. No home network is currently setup, just 3 computers accessing the internet via the router.
Is there a similar forum for networking?
Is that viable for a network or do i need to relocate the router to the pantry and run everything off the 16 port switch?
