Hi,
I have a Dahua DHI-NVR2108HS-8P-I2 NVR running the latest firmware and I want to use the NVR's internal AI analysis to trigger events in Home Assistant.
I have followed the instructions for adding the rroller integration into home assistant and I am getting no movement or SMD events listed in home assistant.
I started to look at the underlying Dahua API and have made some calls using the browser that return 'No events' as a response.
So I am thinking that there is something I need to configure in the Dahua NVR in order to get events out of the API.
When I go to the NVR main page and go to:
Alarm -> Alarm Info
I see events listed such as:
<SMD:4>
<SMD:2>
<Intrusion:4>
And I can click on the play button to show a clip of that event so the NVR seems to be recording events.
What do I need to do in order for those events to show up in the Dahua API, and my assumption would be that they would then appear in Home Assistant via the rroller integration?
Any ideas on what I might need to look at to get things working.
As an aside, I have never seen events listed in the normal search page in the NVR. At the bottom of the search page I see ticks for 'General', 'Alarm', 'Motion' and 'Intell..' but there are no events shown to click on.
If anyone can explain how to get events shown on the search page that would be great.
Alarm -> Alarm Info
<SMD:4>
<SMD:2>
<Intrusion:4>
