Hi everyone. My house has four outside 1080 HIKvision IP cube cams with 128GB sd cards. I can live view from anywhere (IVMS, Guarding Expert) and can save clips from the SD cards from remote playback. There's two way audio. No POE needed as they have separate transformers. No cloud. No panning, but a good wide angle. Had to make at least three changes in the router ports to make the 1080 cams work.
I simply would like the same setup/config BUT with 4k. Dome preferred over bullet.
It also would be super if I could save the config file from each 1080 HIK cube cam and upload it into the 4k cam so it wouldn't need all the tedious interface programming.
Having trouble finding such a model with all these features. Could anyone here please help?
