Hi,
I bough this camera on Amazon :
Aiboostpro Model TY-P12-15
I think this is supposed to be the manual : PTZ WiFi IP Camera User Manual - Manuals+
So i have downloaded the app Tuya.
Scanning the bar code on the camera does not work
Joining it to my 2.4g wifi just says no devices found
Pressing the reset button 3 times or holding in for 2,6 or 10 seconds makes no difference, it only resets the camera.
I cannot get the camera to go into any kind of pairing mode, some manuals i find suggests the camera should flash an indicator rapidly, or say camera is ready to setup, i get nothing of the sort.
Only a voice message when its booted up, "Welcome to your smart camera" or something along those lines
I have queried the camera when connected by wire with nmap.
And it says these ports are used :
Discovered open port 23/tcp on 192.168.0.19
Discovered open port 90/tcp on 192.168.0.19
Discovered open port 8088/tcp on 192.168.0.19
Discovered open port 6668/tcp on 192.168.0.19
I cannot connect with a browser or vlc to any of the above ports
Telnet however works , i managed to find the login details in the net :
root / hkipc2016
cat /proc/cpuinfo ;
~ # cat /proc/cpuinfo
system type : Swan
machine : Unknown
processor : 0
cpu model : Ingenic Xburst V0.0 FPU V0.0
BogoMIPS : 1001.88
wait instruction : yes
microsecond timers : no
tlb_entries : 32
extra interrupt vector : yes
hardware watchpoint : yes, count: 1, address/irw mask: [0x0fff]
isa : mips32r1
ASEs implemented :
shadow register sets : 1
kscratch registers : 7
core : 0
VCED exceptions : not available
VCEI exceptions : not available
Hardware : isvp
Serial : 00000000 00000000 00000000 00000000
Anyone have any ideas how i can make this camera work for me?
What i want to do is :
1 connect it to my wifi
2 enable onvif and get the correct url for adding it to my camera server (Zoneminder)
3 Set a static IP address
Any help would be very appreciated!
Best Regards
Patric
Kameraövervakning utomhus, 3 MP AIBOOSTPRO 1536p övervakningskamera utomhus WLAN, PTZ IP-kamera utomhus med automatisk spårning, 30 m färg mörkerseende, 2-vägs ljud, IP66 vattentät : Amazon.se: Elektronik
www.amazon.se
root / hkipc2016
cat /proc/cpuinfo ;
system type : Swan
machine : Unknown
processor : 0
BogoMIPS : 1001.88
tlb_entries : 32
isa : mips32r1
ASEs implemented :
core : 0
Hardware : isvp
Best Regards
Patric
