Hi - I purchased a house that is 3 years old and has 3 HikVision dome cameras and an NVR. The previous homeowner knew nothing about the setup and never used it or understood it. I have a few issues and questions.
1. one of the 3 cameras continous drops off and shows no link. IF I disconnect the cable from the NVR and restart the NVR and then reconnect then the camera will come back on but then drops off within the next 12 hours or so. Any thoughts on the issue?
2. I have tried setting up motion alerts but nothing gets pushed to my phone. I setup all the zones and set to send notification to monitoring center and also have the notifications enabled on my HikConnect and iphone but nothing gets pushed. At our old house we had Arlo cameras and I miss knowing when someone pulls in to the driveway or is walking to front door. Are there settings I can check for this? I have the NVR plugged into a Google wifi puck, not the router.. could that cause issues? The cameras are online as I can view them through the Hik Connect app but just do not get alerts.
3. Is there a better option for user friendliness than Hikvision? I miss the easier use of the Arlo app but understand this is a much higher quality video and stores a lot more but I do want the convenience of viewing the cameras and getting alerts.
Thanks for any help!
