Help with DS-7616NI-E2/16P
OICU2
BIT Beta Team
Jan 12, 2016
921
1,663
USofA
Hi folks, long time Hik camera user but first time acquiring one of their NVR's. I have picked up a DS-7616NI-E2/16P NVR and would like to add my existing 12 Hikvision POE cams manually via my existing network and not plugging them directly into the NVR. In the camera setup section, it sees all my cameras but it also has the default 16 ports listed. It won't let me delete those default 16 and/or add my existing cameras. What am I missing?
Any help appreciated!
Next question is how to get the stream from the NVR into BI.. I know I need to add it as a "camera" but it's refusing the connection from BI.
Edit: got that figured out as well with the correct username and password.
Couple more questions on this NVR:
Two of my cameras are lised as "Camera 01" in the NVR. Nothing I change directly on the cameras web interface will change how it appears in the NVR.
Secondly, it seems the NVR keeps changing the resolution on one of my cameras to 2048x1536 even though I change it directly on the cameras web interface to 1920x1080.
Any ideas on either of these?
The camera web interface can be used to change the OSD that overlays the video.
The NVR channel name can be changed in the NVR web GUI by changing the camera name.
On the resolution - the NVR has admin control of the connected Hikvision cameras and will periodically apply the settings that are specified in the NVR configuration for the cameras, so that would be the place to define it.
