C Chaoscript Getting the hang of it Aug 11, 2015 212 10 Sep 30, 2015 #1 Hi, Please need help to configare the NVR, What I suppose to do here? Regards. Attachments 1234.png 101 KB · Views: 26
D Del Boy Getting comfortable Mar 19, 2015 2,723 294 UK - England Sep 30, 2015 #2 Tick all the left ones for now. That'll get you started. Reactions: Chaoscript
alastairstevenson Staff member Oct 28, 2014 16,232 7,007 Scotland Sep 30, 2015 #3 When you download and install the plugin - and that works best, for now, with IE11 (not current Chrome or Edge) then all your settings will start from their default values.
C Chaoscript Getting the hang of it Aug 11, 2015 212 10 Sep 30, 2015 #4 I already does that (download and install the plugin), nothing happen, and I can't see the live video in Chrome. Regards.
alastairstevenson Staff member Oct 28, 2014 16,232 7,007 Scotland Sep 30, 2015 #5 An up-to-date Chrome no longer supports that type of plugin. You will need to use IE11 for now.
C Chaoscript Getting the hang of it Aug 11, 2015 212 10 Sep 30, 2015 #6 IE9 will not support? Regards.
alastairstevenson Staff member Oct 28, 2014 16,232 7,007 Scotland Sep 30, 2015 #7 I'm not sure - try it and see. If you get live video - then you are good, and you can change settings.
C Chaoscript Getting the hang of it Aug 11, 2015 212 10 Sep 30, 2015 #8 Edit, Works with IE9, not with IE9 64Bit. Regards.
