- Jul 28, 2015
- 52
- 18
After adding 6 new cameras I'm looking for some improvements on our CPU performance as our server is running about 85% CPU for BI and overall 92-95%. I've followed this post (Optimizing Blue Iris's CPU Usage | IP Cam Talk) and have done all of them except for the 'Limit decoding unless required' option. I noticed with this checked on all cameras CPU was down to only 15% but noticed that the motion detection wasn't picking up a lot of actual motion needing to record and saw from a different post this is a downfall. Anyways was wondering if there are any other tweaks I can apply to help CPU performance without loosing motion dection? Thanks for the help.
Most settings listed below, not a network issue as on the BI server with a webpage open to the cameras stream is clear with 0 lag. h.264 HW decode: yes no VPP
BI Specs: Tweaks listed in above post - Camera FPS to 20 - Prerecord 7sec - 20sec after record.
Our current DVR system is as follows
Xeon E5-2690 2.90ghz (2 sockets) 16 total cores - 32GB memory - Integrated Video - 22 Cameras Hikvision/NSC - 55TB usable Raid 5 or 6 (cant remember)
Camera Specs: 25fps - 1080p or Higher Resolution - Constant bitrate - max @ 2048Kbps - H.264 encoding
8 - DS-2CD2032-I
3 - NSC-4A320-PTZir
4 - NSC-204-BT
2 - NSC-2X4-DM
6 - XC-2032FI
8 - DS-2CD2032-I
3 - NSC-4A320-PTZir
4 - NSC-204-BT
2 - NSC-2X4-DM
6 - XC-2032FI
