- Nov 15, 2015
- 29
- 0
Hey everyone - my name is John. I've been lurking off and on the forums for a few months. I have a location with a 16 camera analog system ( 2 of them being PTZs) and I'm looking at putting together an IP camera system for a car wash. This will be my first system, and feel I can tackle the job.
What I'm looking for in a system:
1. Good remote viewing ability. Need to remote view from both an smartphone(iPhone and Android) and MacBook Pro
2. Good to very good ability to pick plates from at least one camera from a distance of up 30' day or night. Good night time performance. I'd like to use a PTZ for this.
3. Being able to scan specific cameras & motion detected events.
4. Under $5K.
I plan on pulling all new cat5e to a central location in my equipment room. The 12 fixed cameras basically oversee certain aspects of the wash. The self service bays, automatics, vacs, dog wash room, etc. The PTZ's are located on the SW and NE corners of the building. I monitor this wash pretty constantly and use the PTZ to zoom in on people using the vacs and other items. The wash is illuminated all night, I'd say 50% as bright as it is during a clear day. Everywhere where a camera is located is illuminated to some degree.
1. Need help deciding on what equipment is best given my situation, requirement and budget. Should I go with 2,3,4 or 5MB cameras?
2. I'd like to keep the budget around $4K =/- Regarding the NVR, will 12TB give me enough space to keep about a weeks worth of video? I hope the motion detection on the cameras is somewhat accurate solely in the name of saving space on the HDD. I also need to easily access remotely to view live and review recorded events from both my MacBookPro, iPhone or android.
3. It's either Hikvision or Dahua I guess. Just out of curiosity I built a system with the following ( From Nelly's, but am also considering AlieExpress and LTS):
A. (12) NSC-215-DM 5MP WDR Fixed Dome IP Security Camera 2.8mm
B. (2) NSC-71820X-PTZir Infrared PTZ Dome Hi Def 2MP 1080p 20x Security Camera 4.7-94mm
C. NSN-7164K-16P 16 Channel 4K POE Plug N Play Hi Def NVR Recorder
D. (3) WD Purple 4TB HDD from Amazon
I assume I won't need some type of POE switch given that NVR has 16 POE ports, no?
What do you guys think? This will be at the upper end of my budget and would like to spend less. Do you guys think it's overkill given my situation ( Location, Needs, Budget, etc?)
Any suggestions are welcomed. Thanks!
I can also add screen shoot pics of my current cctv screens on my iPhone so as to give an idea of what I'm watching.
4. Under $5K.
