eed some advice for a bricked HUACAM HCV712.
When I first started putting in my camera system I bought Huacam because they were cheap. I believe they are Grandstream knockoffs.
You get what you pay for and all but two have been replaced with HIKvision.
The last two should be here in a couple of weeks.
Meanwhile one has gotten itself bricked. Not the most important security camera but I'd still like to have it working.
Symptoms:
I can not access the camera with a browser or the Huacan IP search or config program.
An IP Search program does not show the camera. It's getting POE because the camera is warm but I have no way to access it.
Before I take it apart - does anyone know if there's a reset button inside?
Any tricks to finding what IP it's on, if that's possible.
Thanks for the help.
Symptoms:
