Hi,
I have updated my NVR DS-7732NI-I4/16P1620171106CCRR128367835WCV
from V3.4.93_V170714 to V4.1.54_V180621 with USB stick
now it comes up requesting password (my old PW does not work, 12345 does not work)
I did a password request thru SADPTool the change was accepted but does not work (Device rejected)
on the monitor login the admin box is filled with unreadable signs. I cant type in admin!
(Login Screen.jpg and Login admin selected.jpg)
used the hikvision TFTPserv.exe to put different firmware on
it does connect - transmitting and does this again and again every second. (TFTPjpg)
it stops after more then an hour and still the same (I used NVR_K51_BL_ML_STD_V3.4.96_17092 and
NVR_K51_BL_ML_STD_V4.1.54_180621 and nothing has changed, can not get in)
What went wrong?
please help me
cheers
Winni
Login Screen
What went wrong?
please help me
cheers
Winni
Login Screen
firmware from eu portal.
