F f13dfx Getting the hang of it Oct 15, 2015 102 47 Dec 7, 2015 #1 Hi. Finally paid & downloaded v4.0. Installed on fresh install of Win7 64bit fully updated. Errors out when starting app. Already installed MS C+++ Redis. & 4.0 .NET Framework. Does this need Win8.1 ir higher? Sent from my iPhone using Tapatalk
fenderman Staff member Mar 9, 2014 36,891 21,408 Dec 7, 2015 #2 f13dfx said: Hi. Finally paid & downloaded v4.0. Installed on fresh install of Win7 64bit fully updated. Errors out when starting app. Already installed MS C+++ Redis. & 4.0 .NET Framework. Does this need Win8.1 ir higher? Sent from my iPhone using Tapatalk Click to expand... No it does not. Have you fully updated your windows 7 install with all service packs? What errors are you getting?
F f13dfx Getting the hang of it Oct 15, 2015 102 47 Dec 7, 2015 #3 Yes Sent from my iPhone using Tapatalk
fenderman Staff member Mar 9, 2014 36,891 21,408 Dec 7, 2015 #4 f13dfx said: Yes Sent from my iPhone using Tapatalk Click to expand... what errors are you getting?
F f13dfx Getting the hang of it Oct 15, 2015 102 47 Dec 7, 2015 #5 Will check again just to make sure Sent from my iPhone using Tapatalk
F f13dfx Getting the hang of it Oct 15, 2015 102 47 Dec 7, 2015 #6 Ok my bad, there was another update that I failed to install. Now up & running. How can I import my v3.9 Blue Iris.reg file? Sent from my iPhone using Tapatalk
fenderman Staff member Mar 9, 2014 36,891 21,408 Dec 7, 2015 #7 f13dfx said: Ok my bad, there was another update that I failed to install. Now up & running. How can I import my v3.9 Blue Iris.reg file? Sent from my iPhone using Tapatalk Click to expand... https://www.ipcamtalk.com/showthread.php/3856-importing-V3-settings-into-V4
F f13dfx Getting the hang of it Oct 15, 2015 102 47 Dec 8, 2015 #8 For some reason the link's procedure didn't work. This was what I always did anytime I upgraded my BI dedicated PC. It's all good. I just reconfigured everything. Thanks for all your help!!! Sent from my iPhone using Tapatalk
