How can i reinstall a firmware if the camera aborts the boot process even before loading the network drivers. This means that the camera is no longer accessible via its IP. I can start update via a serial connection, a network connection is also established. But the tftp transfer aborts after a short time. In the bootloader there is the possibility to update the firmware with upfusb. But you need a special bin-file. Can someone help here?
