Help setup surveillance for main house and guest house
a10hog
Aug 2, 2015
12
Hi,
I am a new member and in needs of help. I've been reading through the forum about different cameras and nvr setup. However, the more I read, the more I see so many different options and they becoming very confusing..
I am looking for 16 ch setup with at least 8 cameras to expand to 12 or 16 later.
A big plus is to have a system to be able to send a 30 second clips to google cloud or drop box when detected motion while it still records 24/7 to nvr/computer.
My current situation is that I have a main house and a guest house for my in-laws. Currently the guest house shares the same network as the main house via wifi.
Is it possible to do the followings?
- The nvr is at the main house with 8ch poe and connect to internet for remote viewing / etc.
- The guest house would have 4ch poe and go to a network switch to local access point which is then connect back to nvr somehow. This local access point is different from the wireless network.
Please help to suggest if this is possible with 3 systems below or do I need to build a pc/server with Blue Iris (I am afraid this route might be a lot more work to setup).
Any preference to the 3 setup below?
Costco: Q-See 16 Channel HD NVR Security System with 3TB HDD and 8 4MP HD IP Cameras
http://www.costco.com/Q-See-16-Channel-HD-NVR-Security-System-with-3TB-HDD-and-8-4MP-HD-IP-Cameras.product.100213199.html
Swann 16 Channel HD NVR Security System with 3TB HDD and 8 3MP HD IP Cameras
http://www.costco.com/Swann-16-Channel-HD-NVR-Security-System-with-3TB-HDD-and-8-3MP-HD-IP-Cameras.product.100144944.html
Homedepot:
Laview 16-Channel Full HD IP Indoor/Outdoor Surveillance 3TB NVR System (8) 1080P Cameras Free Remote View and Digital Zoom
http://www.homedepot.com/p/LaView-1...-and-Digital-Zoom-LV-KN996P168A4-T3/206085556
