Starting over sounds like the right approach at this time!
OpenVPN works with Windows, but you were trying to set up OpenVPN on the Windows computer thinking that is how you would connect to it, but it needs to be done in the router.
You do not need to do anything with the Windows BI computer and OpenVPN.
Here are the general steps with OpenVPN on a router that supports it:
You will need to create a DDNS as your WAN IP address is subject to change at anytime by your ISP (although most do not change often) or you can skip DDNS and pay for a static IP address if your ISP offers that.
OpenVPN is simple, but we make it way more difficult than it needs to be lol.
I was there too once with OpenVPN...tried to do all this research to find directions and got to the point I said screw it and just enabled it and kinda of followed what it was asking and it worked.
Just go to OpenVPN and enable it and see what it says - asks you to create a user/PW, DDNS name, encryption method, and create certificate. Then email that certificate to you (or connect your device to a computer and copy it over) and save the certificate on your mobile device. Then install the OpenVPN app and select the certificate and then connect whenever away from home and you are on your home network.
It really is simpler than our minds make it out to be.
While this is for an Asus, the concept is the same:
randyshomeprojects.blogspot.com
OpenVPN on a Asus router
Sept 2021 Turned off comments because of ads July 2021 Bought a new Asus router, an RT-AX86U. Loaded it right away with Merlin firmware, s...
