Hi all. Looking for a solid IP camera to cover backyard. About 140ft back to the tree line and 80-100ft on either side of the mounting location and also a back patio area right next to the mounting location and a little behind it. Will be run with BlueIris, of course. Ok spending up to $500 for a quality camera, if needed, with good night vision (I was focusing on ones with a nice IR light source because otherwise I think it will be very difficult to see if there is anything at the tree line) and best at monitoring this fairly large space. I'll be using POE to run power and data. Most likely mounting location is on a wall siding (with builders edge mounting plate). Could do a ceiling mount (directly on a roof soffit) if it was a lightweight turret but not sure if those are up to covering a large area like my backyard, which is why I was focusing more on the pendant style camera.
I have been looking at the following:
Reolink RLC-423 - 5MP PTZ PoE Security IP Camera
2K HD Outdoor PTZ IP Camera with 12× Optical Zoom, 330ft IR Night Vision, Color Night Vision, Metal Camera
amcrest.com
Any suggestions on the above or others I should consider, let me know. Thanks all.
Amcrest 4MP Outdoor PTZ PoE + IP Camera Pan Tilt Zoom (Optical 25x Motorized) PoE+ Camera Security Speed Dome, PoE+ (802.3at) 4MP, IP4M-1063EW-AI
AMCREST MODEL: IP4M-1063EW-AI FEATURES: This PTZ Speed Dome PoE AI Camera features Smart Motion Detection (SMD) which allows the camera to detect and filter between human and vehicle motion events. IVS features (tripwire and intrusion) for perimeter protection, and face detection to detect...
