- Jan 1, 2016
- 6
- 0
This is about as NEWBIE post as it gets. I'm struggling here guys. My eyes are burning red and I'm trying to learn how to fix my camera networking issues and just keep failing.
I told myself I won't give up but I've found myself calling in local camera support. No one is getting back to me or heard of my issues before, although they seem to be talked about alot here on this forum.
I've spent 7 hours or so today trying to understand code and fix my chinese Hikvision cameras.
All of them are visible intermittently on Hikvisions SADP, the 2 of 8 american ones visible the most often.
Weird right??? I can web login only to the american ones. I just imagine the chinese ones are in boot cycles/bricked or frozen and that is why they pop up intermitently in SADP. I can't find anyone that had this problem in all the reading I've done. I've heard of bricked. Not logging in, etc, but never itermitently showing up in SADP.
None of these cameras have manual reset buttons and I want to throw my fist through the wall at this point.
**EDIT**
Got it all to work using a 3.1.6 hacked firmware that someone posted. I was able to download Hikvisions TFTP file by also grabbing the 3.3 to 3.2.5 downgrade .rar that is floating around the forum on someones dropbox.
I can't believe how crappy hikvision does at letting you search support files and organizing them for download
Good day all! PM me if you want some help. Definitely need to pay it forward now.
**EDIT**
