gpower07 Getting comfortable Dec 8, 2014 866 179 Tracy, California Feb 21, 2020 #1 they close today and weekend. anyone have tool to generate the code? here is the file..thank you very much. i also tried TTL serial cable. it will not support update command anymore. Attachments DS-7208HUHI-K10820170623CCWR784123501WCVU-202002211552.xml DS-7208HUHI-K10820170623CCWR784123501WCVU-202002211552.xml 217 bytes · Views: 2 Last edited: Feb 22, 2020
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,331 48,145 Alabama Feb 21, 2020 #2 Try IPCT's tool ==>> Hikvision Password Reset Tool
gpower07 Getting comfortable Dec 8, 2014 866 179 Tracy, California Feb 21, 2020 #3 TonyR said: Try IPCT's tool ==>> Hikvision Password Reset Tool Click to expand... it has the new firmware. Last edited: Feb 21, 2020
