you can assign the camera an IP address inside the Vlan. and I believe you can set the Amcrest APP to connect to the camera via a DDNS name, or an IP address ( static) and, /or P2P with a QR code.
and with the IP (static) setup you can keep it all on the local network.
My experience is with Amcrest DVR/NVR's that connect to Blue iris, or standalone.
But the Amcrest 841 ptz will be available to initialize at 192.168.1.108, on a browser. from there set a password and change the Ip address.
There are version 2 and version 3 of this camera I think.....maybe newer versions of this cam support newer browsers.
but you will need to interact with the camera from Interet Explorer, or EDge, or Chrome with the IE tab.
