- Jun 22, 2016
- 192
- 15
Evening all, I bought some Turrets of my home and having some confusion on how I am going to mount them. I'm planning to put them under the soffits but not sure technically how I get the ethernet cable there. Do I need a junction box? If so, the boxes I saw for the Turret have the port on the side, I was hoping not to have any wires exposed and run them from the attic straight through the soffit to the camera. BUT when I check to see on mounting it without the junction box to the soffit it doesn't seem like I can wrap the wire inside the housing. I'm sure a professional installer would know, hoping for some info/help with that or pics.
Thanks!
Thanks!
